John.t.little1
- Oct 10, 2014
- St. Augustine, FL
Thanks for any help in advance. Machine is a bridgeport interact series 1 with TNC 151B.
I am wanting to make my first program and the more I read the more I forget what I've just read. I'm more of a hands on learner. Having said that I don't know how to start a cycle of code and exactly what some codes do. For instance I've pieces together this for some steel plate I want a bolt pattern in.
S573 M03
G01 X3.346 Y0.000 F240
G73 Z0.25 F24
Now my main question is does the G73 automatically return to zero after the peck drill completes? If not where do I go from here? I'm doing a bolt hole pattern planned to spot drill the holes than tool change and drill completely G81? I can't run these in a simulator Bc the screen went out on my laptop. -John
S573 M03
G73 Z0.25 F24
