MrM0j0
- Jan 2, 2015
- Byron Center
Having problems programming radial slots in 304 Stainless. Started out breaking end mills. seemed to have fixed that issue, for the time being anyway, but now the shape of one of my slots has changed. The only change in the program I have made is adding some position blocks so i'm not running my end mill into my part. I have 2 slots in the front of the front of the part, dim., .142 x .105 and .085 x .140. I added a pocket in the back of the part, .160 x .100. The problem I am now having is the .085 slot has changed shape. I am using a 1/16 end mill and originally had it programmed to cut the slot width at .085, it actually cut it at .092, which is about .007 too big so I changed the program to cut slot width at .07 to see if that would make the slot smaller and it actually cut it at .100 plus the shape of it changed. Can somebody explain this to me?
