Hello modelubys,
1.You have to find the I and K values of the Triangle shown in the following picture.
2.h (the hypotenuse) will be the Feature Radius minus Tool Nose Radius.
h = 10-2
h = 8
3.because the complementary angles of the triangle are 45deg (the included angle of the lines tangent to the radius is 90), I and K will be the same Absolute value; therefore I and K will be:
I = SQR((h^2)/2)
I = SQR(64/2)
I = 5.657
K = 5.657
4.The centre coordinates of the 10Radius can be obtained from the drawing; X103.28 Z-31.0
5.The centre coordinates of the Tool Nose Rad at the start of the 10rad will be
X = 103.28 – 5.657 x 2
X = 91.966
Z = -31 + 5.657
Z = -25.343
6.The above are the coordinates of the TNR centre; you need the coordinates for how the tool was set. From your original program, it can be seen that the Leading Edge in Z and the point on the insert closest to the machine centre line in X were used (Tool Type 3 setting)
7.To get the X coordinate subtract the TNR x 2 from X91.966
X = 91.966 – 4
X87.966
8.To get the Z coordinate subtract the TNR from Z-25.343
Z = -25.343 – 2
Z-27.343
9.For the tool position at the end of the radius, the X will be the same as at the start of the radius; Z will be the Z centre of the 10radius minus the K value from point 3, minus the TNR
Z = -31- 5.657-2
Z-38.657
When I/K Circular Interpolation Format is used, the I and K values used in the program are distances and direction (+ or -) from the centre of the TNR to the centre of the radius being cut.
Regards,
Bill
