dkmc
- Jan 13, 2002
In a previous post of mine here, the subject came up on older VMC's spindle speeds. Most from the 1980's were limited to 3500-4000 RPM.
Modern VMC's easily run 6000-8000, but I have heard the spindle design is supposedly different to allow cooling of the bearings by oil or coolant circulation.
It occurs to me that some modern CNC lathe spindles are designed to run similar speeds, and I have seen the headstock designs first hand. No 'extra' provision like coolant or oil circulation is incorporated to cool the bearings.
At what RPM does 'additional' cooling come into play? I want to run a VMC spindle orig. designed for 3500 RPM at 5000-6000 RPM.
Fitting modern bearings is an option if required.
Incorporating 'coolant circulation' is not.
dan k
dan k
