Zebu
- Mar 27, 2006
- Phelps NY, USA
I have been having problems sending code to our Prototurn Lathe with a Fagor 8025 control. The code is for a chess piece part of our senior project. I am the first in the class to try to get this machine networked to a PC and have been having many problems getting it to work.
The coding is done is Mastercam X2 MR1 with a Fagor 8025 post processer. I have tried using the Mastercam post to send the code direct to machine but this has never worked. The control displays recieving on the screen but hangs on this step, I believe this is because Mastercam is not setup to send the end of transmission codes.
I also downloaded and installed WinDNC from the Fagor website but was not able to get this working at all. I am not sure if I am missing a part of the program but I cannot find the options screen to setup the machine controller type.
Last I installed NCnet Lite, this seems like excellent software for what I am looking to do but when I use it to send the .nc file to the machine it gives me an error, I'm not remembering exactly what the terms were but it seemed like a generic files not compatible/ file type not right error. I also tried to send the code in .txt files with the same result.
If anyone here uses this control I would be grateful if you could explain how you load programs, the software you use, and what connection settings you have set.
Could I be missing a critical setting on the control side or does this sound like a PC side problem to you?
I'm looking for any and all advice so if you think you may know what is happening please post.
Erik Fellenz
Erik Fellenz
