Wade C
Stainless
- Jul 21, 2004
- Wiggins CO. USA
Sealing the Deal
Since I got the machine, it has had a little bit of a Hyd Oil leak... not horrible - Maybe a gallon over a year of intermittent use. Last Dec I noticed it was a little more than that. Then starting in May, its gotten even worse. As of the fill up of the hyd reservoir on saturday evening, and about 16 hours of run time, its pumped about 2 gallons into the coolant tank - from dripping off the Z axis turret carriage way cover.
I managed to forget my manual at home, so I havent looked through the diagrams yet, but I thought Id post up here to see if anyone has been in these and can offer suggestions of places to start or suggestions for "replace this while your in there - you wont regret it".
The way its leaking and where (about 3" in front of the turret - dripping out from under the way cover, then down the slide onto the casting and then into the chip pan) - I just get the feeling "hose" - maybe a pinhole leak in the hose or a fitting lossened? Of course, not knowing what all is under there, it could be seals from the turret and just happens to flow back to the way cover and come out there... So Ill be digging into that.
Also, the Hyd Chuck closer has a little bit of a leak and the turret has a leak on its main shaft... not horrible, but tempting to replace those seals too. Is that a huge undertaking? Id guess the turret could be a huge undertaking... or not. The closer seems like it would be pretty straight forward.
So there is my upcoming "projects" - and Ill be pouring through the manual, but I dont remember really good schematic breakdowns on the assemblies - so Im a bit worried that I wont find any diagrams that will help and be at the mecry of my own intuition as I pull pieces off.
Thoughts, opinions, explinations, etc... all welcome and appreciated.
Wade
Wade
