Huh? It's a lathe. There's no G50 for X.
He specifically said "home position" and "home lights" on the panel.
Hello ewlsey,
I agree, the OP is referring to the Reference Return Position when he mentions the "home lights on the panel".
Fanuc Lathe Controls can be set to use one of three different G Code Systems, A,B and C. There are two different G Codes used to set the Coordinate Systems for a lathe, depending on the G Code System being used (G50 and G92). Overwhelmingly, Fanuc controls use G Code System A and therefore, will typically use G50 to set the Coordinate System. Machining Centre Controls use G92 to set the Coordinate System.
litlerob1 said:
The older Fanuc's use G50 as a reference return position, so
o1111
G50 S1000 X$#^% Z@#$@
Go program
program
program
G28 U0 W0 (return to G50 reference return)
Hello Rob,
That is not how it works. G50 is used to set a Coordinate System and it can be executed at any axes slide position. However, when G50 is used to set a Coordinate System, it must be executed with the axes slides in the same position for every execution of the program. For this reason, its often the case that G50 is executed with the axis slides at the Reference Return Position; but G50 doesn't set the Reference Return position.
To make your program example correct, it would be written as follows with a G28 U0.0 W0.0 preceding the G50 Block.
o1111
G28 U0 W0
Go program
program
program
G28 U0 W0 (return to the reference return - which happens to also be the G50 Coordinate System Set position)
If your original example were to be run with the X and Z axes, say 100.0mm away from the Machine Reference Return position, the slides would return to the Reference Return position when the G28 U0 W0 at the end of your program is executed. The next execution of the program would result in the axes slides (and therefore the tool) being 100.0mm out of position for each axis.
A Fanuc 11T control will generally be supplied with the G54 to G59 Work-shift Offset option and would be used in preference to setting the Coordinate System using G50.
Regards,
Bill
