Atomkinder
Titanium
- May 8, 2012
- Mid-Iowa, USA
An introduction: I have a project I'm working on to challenge myself. It's a small ornament ('tis the season, right?) made from 1" round stock using Fusion 360 and 4th axis positioning, 3D surfacing, and eventually a breakoff "tab" that will be buffed out, leaving a finished part.
I'm hoping that some folks can chime in with how they work with complete parts in a 4- or 5-axis setup and wind up with that little tab they can bend the part off of. HSMWorks experience would probably be most relevant, but really any input is good. Do you limit machining areas with sketches, or create extra stock solids to work from as the job progresses? How much indexing is used, and what orientations do you find to be important?
I'm pushing myself where work likely won't so I can learn and get better. Here's sort of where I'm at now, but this may change in the next 12 hours
