madengr
- Nov 3, 2003
- Overland Park, KS, USA
Let's say you want to cut a square boss on a CNC mill. You write your code (or use a cam program) to cut it to 1.000" x 1.000" . You then measure and it is 1.001" x 1.001" . Is there a method to take off the remaining 0.001" without having to re-compute all the tool paths?
I ask this since we were taught on manual mills in my machining class to work incremtally. Cut, mesure, cut some more, measure... until you get it within tolerance. You don't want to over-cut and ruin the part.
It seems to me that tight tolerence CNC machining is tricky since working incremetally would require several runs. Do you always cut the part oversize, measure, and re-generate the toolpaths for those features that are not to spec?
