Nerdlinger
Stainless
- Aug 10, 2013
- Chicago, IL
Hey all! I am not used to holes with such a tight tolerance. I need to cross drill .125" +/- .0002 in 3/4" round 1018. Will a high quality 1/8" carbide do it or should I go a size under and then ream? Production would be in a tight Brother S700 (not sure what the runout is but no crashes (yet)) so it should be pretty good.
Bonus question - For starters I tried using some carbide metric equivalent of .1245" in a Haas TM-1. I didn't "measure" the hole but the no-go gage go'd, so it drilled oversize by at least .0008". I put an indicator on the drill and measured .0015" TIR. Will that actually translate to the hole being .0015" larger with carbide?
Thanks!
Thanks!
