Finegrain
- Sep 6, 2007
- Seattle, Washington
Hi guys,
(ugh, title misspelling, "induce" not "indujce")
Got a new 1-1/4" thru-coolant boring bar. It has three flats. If I simply bring coolant to the back of the boring bar holder ID via the ports in my boring bar holder (Mori Seiki SL-2B), most of the coolant will run through the flats instead of going through the bar to the tip.
How do you handle this? I thought maybe just seal off the flats with silicone, but I also adjust the extension of the boring bar now and then, and would have to re-caulk every time. I have also plumbed a vinyl hose from one of the turret ports around to the back of the bar before, but this is a hassle to set up each time.
Thanks, and regards.
Mike
Mike
