ricardo_gt
- Aug 5, 2012
- Portugal
So you are you creating the torx feature? You don't say what size torx. You'll have to use a carbide drill, a carbide endmill and a ball endmill. Its going to be time consuming. And you WILL be breaking tools.
Size 40, it is at the print: Iso 10664-40 (torx - size 40).
Rotary tools are very expensive...
Is it possible, using the lathe live tool, with the torx bit, rotating at same rpm as spindle rotates, to do the same effect as using a rotary broach tool with rotary tool holder? I mean, just buying the torx bit (200 dollar),and using the front live tool, is it possible to do it? Spending 1200 dollar on a holder is very expensive... i have never done this type of job and i am feeling a bit lost in here...
Thank you for helping.
Someone on here a while ago was using rotary broaches in a live tool holder, the fancy kind that
you can set up off angle(2 degrees).. If I remember correctly he was getting far better tool life by syncing
the broach to the spindle than letting the spindle grab the broach and bring it up to speed. .
I must have missed that. Can you link it?
@BobW Are you thinking of this?
NEW Rotary Broach / Wobble Broach Tool Holder 3/4" shank for 1/2" shank broaches | eBay
If that is expensive to you, you're in the wrong game.
Notice
