how to machine a long bore?
Results 1 to 13 of 13
    Sep 2008
    Florida
    331
    26
    86
    Default how to machine a long bore?
    I have somewhat of a challenge here for CNC lathe. 1.063 dia. blind bore, +.002/-.000, 8.45 deep, flat bottomed. 6061-T6 aluminum part. Ream? Tools I find aren't long enough. Getting chips out is going to be a challenge as well. Any suggestions?
    Jan 2012
    Canada, Edmonton
    596
    60
    208
    How many parts? you could use a 0.875 devibe and a TCMT go from back to front. Run once pull chips, run a second time to size - you might be able to get it to size in one pass - try different things if something isn't working. There are reaming tools that you can use with extensions. Can't seem to download the link but here might be something.
    AlliedMachine.com
    Jan 2007
    Norfolk, UK
    16,894
    12534
    12021
    Apr 2005
    Beaverdam, Virginia
    5,790
    198
    2321
    How is your turret\reamer holder alignment to the spindle? If it isn't dead nuts you are going to have to bore it to hold +/-.001 over 8" deep.
    Jan 2007
    Massachusetts
    5,105
    642
    1014
    Just what is allowed at the bottom of the bore regarding corner radius, flatness and finish? That could be your bigger problem than bore diameter, tolerance and length.
    Aug 2002
    West Unity, Ohio
    23,089
    3396
    6388
    A long Allied Drill to depth, with a flat bottom of the same size comming in behind it, both with HP coolant will do a decent job on this.
    When the tool shanks get this long, they will pull onto center way better than a short stubby one, so more likely to drill to size.
    Best bet is to drill slightly under and ream in.
    But you would want a reamer with a through tool coolant port, and I don't know much available for that.
    I have had to have some of them made that way.
    Think Snow Eh!
    Ox
    Sep 2008
    Florida
    331
    26
    86
    Thanks guys, for the ideas. I'm trying to get the engineer to cut me some slack at the bottom of the hole, so it doesn't have to be finished to the very bottom. I was thinking as were you that I'm gonna have to get some serious coolant through the tool to get the chips out that deep.
    Apr 2005
    Beaverdam, Virginia
    5,790
    198
    2321
    Quote Originally Posted by rainman View Post
    First thing I do when I see a flat bottom is too ask if I can have a drill point and how big.
    Jan 2007
    Norfolk, UK
    16,894
    12534
    12021
    Quote Originally Posted by Dualkit View Post
    Same here, and when they ask why? I play the cost card - surprising how many minds that changes
  10. Likes david n, Ray Behner, Philabuster liked this post
  11. #10
    Apr 2005
    Beaverdam, Virginia
    5,790
    198
    2321
    I found a lot of flat bottoms that are called out are for springs so the flat part doesn't have to be very wide in most cases.
  12. #11
    Apr 2007
    Pillager, MN
    5,295
    1685
    4532
    Many times I call the customer before I even quote the part and let them know what features are going to hit their wallets the most. As Sami said, it changes minds right quick.
  13. #12
    Sep 2008
    Florida
    331
    26
    86
    Thanks again. Only problem here is that this is an in-house thing. Although cost should be important to engineers, it isn't always. This is for a pneumatic deal, this being a piston bore. I'm hoping when the engineer looks at it closer, he'll find that the piston doesn't go all the way to the bottom, and can allow a certain distance from bottom that's not to size
  14. #13
    Apr 2005
    Beaverdam, Virginia
    5,790
    198
    2321
    I have been self employed for over 15 years but I really enjoyed those engineer vs machinist battles when I worked at a large company in the 80's. If you can prove your design will save money and be just as functional you will win the battle 100% of the time. Of course you may have to take your battle pretty high up the ladder.
