Ddgman2001
- Feb 8, 2014
- Canada
I have some parts that require a convex surface on the top. They're being machined from 6061 with a 1/4" ball mill using a parallel finishing path. If I machine in both directions, there is a distinct difference between the height of each direction of cut. Leaving a surface finish that is not much smoother than if I'd done half as many passes in a single direction. Is this normal or is my machine just really loose?
