Houndogforever
Hot Rolled
- Oct 20, 2015
- Boring
Picture a rotary table with the center line running parallel to the X axis. Setting X is simple, bump against the end of the part or the end of the blank and you have your X.
Setting Z is also fairly easy as you know what your height to center of your rotation is, and it will always be the same. You can mill a face and rotate and verify height afterwards too.
Now comes Y. Normally on a round part, I just pick up the center of the part/stock and I'm there. But I'm now making a part that is not centered on the Y axis center. It is not a symmetrical part either. I can center on the dovetail fixture which should be pretty close.
My concern comes when it gets down to finishing close tolerance dimensions. With a .001 mis-location on Y and on Z, how can I finesse this down? Is the Z location wrong, or perhaps just the finish tool was off by .0005? What about Y? Narrowing down whether it is a Y fixture location, z tool location or diameter compensation or even tool deflection just sounds like a nightmare to work thru.
Do you guys make a sacrificial part blank and face mill it square to set Z and then put a hole in center of Y to verify set up? What methods do you use to set this up efficiently? I would sure love to gain some knowledge on your methods.
