turbotadd
- Jul 22, 2010
- Stillwater, MN
Wondering how I should go about making this part, Qty. 3. I have 1.5 x 13.13 x 13.13 6061 plates for material. Would it be best to drill all the holes and pocket the reliefs, then try to use the thru holes to hold it down to a subplate? I would add additional holes on the inside and outside. Or bolt up through the subplate to the 3 tapped holes? My concern with doing that is that there is too big of a span between bolts, will get chatter when I do the finish pass around. Thinking 5/8" rougher and 1/2" 3fl carbide finisher.
Machine is 40 taper VMC w/ 20"X 20"Y 16"Z.
There must be a better way...
