eastonmade
- Apr 26, 2015
Hi Guys,
I have some questions about some random stuff and am hoping to get some response to point me in the right direction.
Some background;
I manufacture wood splitters. I started doing this a little over a year ago and have experienced growth drastically beyond what I ever had expected. Most of the stuff we do is fairly rough in comparison to the machining world that most are use to. If we can keep a .005" tolerance we are easily in spec for most stuff (bolt patterns, wedges ect).
I am currently spending 20-30k a month in the local machine shop to plasma cut, bend and machine my parts. I am considering buying a plasma table, brake and machining center and doing it in house. I don't have a lot of experience in this stuff, however I do have a good understanding and the ability to learn quickly.
The biggest most time consuming job for a mill is machining the edge on the knife blades. We also do a couple of bolt patterns and open some holes up after plasma cutting to push bushings into.
the blades are 1" MS (seems to work as good as anything else with much less screwing around). The edge is 15 degrees for a total of 30 overall. I think they typically do it with a face mill with 5 or 6 cutters in it (no coolant). the total length of the cut is 18".
I am wondering what the best mill would be to do this? I need something that is incredibly reliable (as I don't have the knowledge of mills or the time to fix something all the time), fast and preferably easy to program. I am thinking along the lines of a HAAS VF3 or VF4. But am wondering if there is another brand that may be better or another option for me.
thanks in advance for any and all feedback
Some background;
