Alphington
- Nov 22, 2017
A question for owners/operators of integrex I or J series machines or similar multitasking machines. Particularly machines with 2 spindles (left and right) with both upper milling spindle and lower turret.
If you are turning using the lower turret on the left hand spindle, and you simultaneously call a tool change on the milling head, does the weight shift in the machine or the vibrations made during the tool change cause defects/inaccuracies in the turned finish?
