I Know it Has Been Beat to Death, But Fanuc G41/42 Questions
alphonso
Titanium
Feb 15, 2006
Republic of Texas
Fanuc 18MC, Cutter Compensation "C".
Program for threadmilling. New threadmill is slightly smaller OD(.347 as opposed to .35), thus threads are too tight. Thought that we would add comp to program rather than re-post or calculate how much to change values.
Not having any luck, keep getting 034 error.
So, can somebody show me what and where to add G41, D value(112), and G1 lead in? The X-1 Y0 is the position to start threadmilling the first hole.
N310 T12 (1/2 X 13 THREADMILL) M6
N320 G54
N330 G0 G90 X-1.0 Y.0 S4365 M3
N340 G43 Z.2 H12 T15
N350 G72.2 P0071 L3 I1.
N470 M09
N480 M05
N490 G28 G40 G91 Z.0 M09
N500 G28 Y.0
N510 G90
N520 M30
:0071 (SUB FOR 0070)
N370 G1 Z-.8192 F13.1 M8
N380 G3 X-.9435 Y.0 Z-.8 I.0283 J.0 F3.1972
N390 G3 X-.9435 Y.0 Z-.7231 I-.0565 J.0
N400 G40 G3 X-1.0 Y.0 Z-.7038 I-.0283 J.0
N410 G1 Z-.8192 F13.1
N420 G3 X-.9225 Y.0 Z-.8 I.0388 J.0 F4.0208
N430 G3 X-.9225 Y.0 Z-.7231 I-.0775 J.0
N440 G3 X-1.0 Y.0 Z-.7038 I-.0387 J.0
N450 G0 Z.2
N460 M99
N320 G54
N470 M09
N480 M05
N500 G28 Y.0
N510 G90
N520 M30
Your G1 G41 D112 line should go here. You need a linear move
try this
G1 X-.980 Y0
G1 G41 D112 X-1.0 Y0
Cant have G40 on a G3 line, do a lead out same as the entry in reverse
G1 G40 X-.980 Y0
g1 X-1.0 y0
and then the same thing on this pass
N450 G0 Z.2
N460 M99
too short?
Where the fuck did the G40 come from? Edgecam strikes again. I have 5 other programs associated with this project with threadmilling in them and none of them stick G40 anywhere.
I have been operating on the assumption that the G41 should be called in the main program rather than the sub. My thinking is:
N320 G54
N330 G0 G90 X-1.0 Y.0 S4365 M3 <-------- Change to X-.980(or X-1.02) Y.02
G1 G41 H112 X-1. Y0 F.1 <--------- Insert
N470 M09
N480 M05
N500 G28 Y.0
N510 G90
N520 M30
Wouldn't this work if I get rid of the G40 in N400?
This is gonna sound dumb, especially because it ran before you tried to add comp... But is there a reason your height offset (T12) and your D offset (T15) don't match?
It looks like it has an arc in as well as a arc out with no straight line.
Try this for your sub. I just wrote it out long hand the way I do most of my thread mill cycles. Make sure you use the D you need in there for your tool size.
:0071
G1Z-.8192F13.1
G1G91G41Y-.211 F3.1972
G03X.250Y.211I.0031J.25Z.0192
G03X0.Y0.I-.250J0.Z.0769
G03X-.250Y.211I-.2469J-.039Z.0192
G1G40Y-.211
G1G90Z-.8192F13.1
G1G40Y-.211
G0G90Z.2
M99
N320 G54
N470 M09
N480 M05
N500 G28 Y.0
N510 G90
N520 M30
As to whether it would work or not, I don't know.But I would put G40 in the line before G90. I always do. Should cancel it out when it hits M30 I think, but I always call for the control to cancel tool offsets. Seems like I had it NOT cancel one time. Pulled quite a bit of hair(that I can't AFFORD) out on that one, and it may have even been on THAT exact machine.
But you are correct, that is the most glaring error I see. And I missed it as well, reading the OP. As you said, Edgecam strikes again.
