Ikegai ax25z 10T Fanuc control need parameters
Results 1 to 6 of 6
    Aug 2007
    illinois
    37
    Default Ikegai ax25z 10T Fanuc control need parameters
    I Ikegai ax25z 10t fanuc. Poweroutage blew fuse in charger for battery backup. Lost machine parameters didnt have backups. Used machine from ebay didnt get parameters.Need help,searched no luck. Machine needs to run. Anyhelp willing to pay.
    Jun 2004
    Brampton Ontario Canada
    499
    6
    I have the parameters for a 15 of the same year with the same control. I also have the timers, data tables and keep relay setting sheets that you will undoubtedly need as well. I went through the same exercise that you need to and had to reload everything. I erased mine by turning on parameters that weren't originally turned on, if you know what I mean. I can copy the info for you if you would like to try it, I doubt that there would be too many differences and you could probably figure out any that weren't right, such as machine stroke limits etc. There is a ritual that you have to go through to load them into a dead control because DNC won't work due to the lack of communication parameters, I also have the information for that procedure. Let me know if you would like to proceed.
    Glenn @ Metro North.
    Aug 2007
    illinois
    37
    Default ax25z with 10t control
    Maybe you and i can work this out. Same year lathe how!IF give info geatly appreciated would pay.Zstandsfor wHATStarting new machine need help. JUst need machine to run. Need help do you need anything? email [email protected]
    Jun 2004
    499
    6
    I'll copy all info and procedures and email them to you. I will include contact info so that you can call if you are stuck.
    Glenn.
    Jan 2013
    Decatur, TX USA
    25
    14
    Do you still have this? I've got the exact same issue on a ikegai AX15z lathe . Won't boot past the
    Board check screen...
    Quote Originally Posted by metronorth View Post
    Glenn.
    Jan 2018
    Fellas,
    It seems that having Brain Dead Ikegai AX15Z lathes is the latest thing. I am in the same position of no one checking the battery replacement date before the power was irrevocably cut. AND>>>>No record anywhere of parameters. OOPS!!
    So now what was not going to be a problem is now my problem.
    If one of you fine gents would please give me a shout and lend a hand with the restoration of the machine to functional status I would be deeply in your debt.
    Old Iron
    [email protected]
