We have a 3/4" spiral flute tap broke off in a large, heavy, expensive part. Local EDM shop doesn't have height to reach, tapered shaft w/ball on the end and weight conspire against laying it down and doing it sideways. He suggested milling/drilling w/carbide. I have vertical room in VMC- - looking for recommendations on cutters, feeds and speeds. We'll need to start by milling, as end is rough enough that we'll never get a drill started.
Ray
This used to be my job at a shop where they figured out I had worked in a repair atmosphere for a while. You have a lot more wiggle room than I ever did, so here goes how I would approach it.
First, make sure you setup is dead set rigid. A little wiggle will snap the cutting tool like glass.
Start of with a carbide ball mill if you have one. If not, the a center cutting 4 flute will work to get a cut started. Use enough speed or you'll see a built up edge on your cutting tool break off and imbed carbide in your cut. Drill enough to see shavings(dust really) form. Come up, blow it out. Do it again. Those shavings have to be removed before they weld back to the parent metal, and the drill. So blow them out soon as you see them. Don't let them build up. Run it dry, most likely, as this will allow you to see how often to blow it out. You'll drill just a little, blow it out, and keep repeating. Till you get a good start.
Then, you start having options. I used to use a drill called a hi-roc drill. Carbide, no flutes. Ground sorta like a spade drill. LOAD IT IN A GOOD COLLET! NOT A DRILL CHUCK!!! Drill chuck can let that wiggle get you. Drill a bit, at that high speed, blow it out. Repeat. Use a moderate feed. I've done lots of them in a manual mill where I had some touch.
I like the idea of using a helical cut in this case. You have some room. Just stay near the minor diameter. Blow it out frequently, if not constantly. Helical cut would of course require a CNC.
Also, be careful when you get near the bottom, especially if it's broke off deep. If you get all the way through, the parts of the tap left in the hole will collapse on your tool. That sudden load will snap that carbide off in the part, leaving you worse off than you are now. Get almost to the bottom, use a punch to fracture whats left, and remove it with a magnet. Figure out why it broke, clean out the hole and threads with another tap(by hand) being careful of any tap fragments stuck in the threads. Bob's your uncle.
I've removed 1/2x13 spiral flute taps this way and had 3 perfect flutes in my hand with a good part on the bench. Main thing is be patient, don't let the chips build up, and use enough RPMs to prevent a built up edge on your cutting tool.
