Improper G-Code
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Improper G-Code
    Nov 2005
    1,486
    11
    148
    Post
    I was trying to post a program to a Hardinge Cobra Lathe
    Fanuc 21-T Controller
    It gives an Error 010 Improper G-Code
    I have no idea what this means but I will post the first part of the code and see if any of you think you know what is wrong.
    it stops at the G50 S3600
    O0000
    G20
    (PROGRAM NAME - HELP DATE=DD-MM-YY - 04-01-06 TIME=HH:MM - 17:32)
    (TOOL - 1 OFFSET - 1)
    (LROUGH OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432)
    G0T0101
    G97S216M13
    G0G54X3.5341Z.11
    G50S3600
    G96S200
    G99G1Z-2.84F.01
    X3.7339Z-3.0141
    X3.8753Z-2.9434
    G0Z.11
    this is obviously abreivated but it makes it no further than the G50 when you go back to edit.
    No idea that is wrong. Compared it to other programs in the memory that i have ran in the past and see no differences up to that point.
    Jul 2004
    Spartanburg, South Carolina
    1,534
    48
    97
    Post
    What does G99 do?
    Sep 2003
    riverside, ca, usa
    334
    31
    76
    Post
    G99 = ipr feed
    Feb 2005
    Rotterdam
    1,236
    37
    Post
    G0T0101 (=====where is line N101? ===)
    G97S216M13
    G0G54X3.5341Z.11
    G50S3600
    G96S200
    G99G1Z-2.84F.01
    X3.7339Z-3.0141
    X3.8753Z-2.9434
    G0Z.11
    Mar 2005
    New Hampshire
    357
    Post
    Isn't M13- the live tool spindle?
    Cant use ipr
    Mar 2005
    New Hampshire
    357
    Post
    xjen,
    I think thats supposed to be a toolcall with a G0- rapid move- not necessary
    Aug 2005
    Bremerton, Wa
    2,595
    66
    68
    Post
    You called a G96 without ever turning on the spindle....
    Jim
    Apr 2005
    Willoughby, Ohio
    428
    Post
    The alarm #10 is only going to happen if you try to use a G-code that your CNC is not equipped to use. This can happen if there's an option not installed, or if the G-code you're using is not recognized by the control at all.
    Some CNCs are set up to use EIA G-codes instead of the usual Fanuc JIS (Japanese Industrial Standard) G-codes so, for example, G20/21 for inch/metric might really be G70/71 on your machine.
    Try entering each of the G-codes in your program in MDI mode. The alarm #10 will tell you which one is the culprit.
    Mar 2004
    Waukesha, WI
    7,496
    701
    1816
    Post
    I believe on a hardinge, m13 turns on spindle and coolant at the same time.
    Jun 2005
    Michigan
    169
    Post
    I think the G54 is the culprit. Are you using the W.SHIFT to set the z? Can you find G54 etc in the offset pages?
  11. #11
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    175
    Post
    I'll ask the dumb question, are you sure you don't have a letter "O" instead of a zero ?? I'v seen it too many times to count over the years.
  12. #12
    Oct 2005
    England
    3,021
    24
    685
    Post
    Nobody has spotted it have they?
    try G92 S3600 instead of G50 S3600
    Some lathes are funny about that
    Boris
  13. #13
    Nov 2005
    1,486
    11
    148
    Post
    Sorry about not being up to speed on replying. Just got finished welding up some bike frames....
    M13 is spindle counter clockwise on coolant on
    G20 is supposed to be used
    G99 - IPR is what i want to use and is what i have used in the past with this machine
    G96 - Always works
    G50 - has worked in the past.
    Frankly nothing has changed and this thing won't work.
    Gonna get some live help tommorow but any more ideas are very welcome.
    All G codes listed there work in MDI without and alarm.
    G54 is the only one i question but is in other programs. 90% or programs written for this lathe are from mastercam same post, same computer.
    I am literally dumbfounded. I can usaully figure these things out. Can't find the manual that tells what the ararms are either. Damn disorganized shop.
    Husker
  14. #14
    Aug 2005
    CT
    7,534
    248
    1540
    Post
    The only thing, see if programming G54 in it's own block makes a difference.
    Not sure if the machine likes calling a workoffset and positioning in it in the same block.
  15. #15
    Apr 2005
    Willoughby, Ohio
    428
    Post
    Below is a "cut & paste" of text from the 21T operator's manual section on the G54-G59 coordinate systems. In your program, the G54 coordinate system is selected first, then you give it the G50S3600. Normally, the G50S--- command is just to set the upper limit of the spindle speed in CSS so it shouldn't matter, but this statement may explain your problem:
    (from manual):
    When bit 2 (G50) of parameter No. 1202 is set to 1, executing the G50
    command results in the issue of P/S alarm No. 10. This is designed
    to prevent the user from confusing coordinate systems.
    Try giving the G50S3600 command before you select G54.
  16. #16
    Jan 2005
    1,684
    Post
    looks like a mastercam post.
    error may be further in the program.
  17. #17
    Aug 2005
    CT
    7,534
    248
    1540
    Post
    Dan
    Wonderful example of Japano-English translation.
    Does that mean that G50 can only be invoked at the beginning of the program and never again until an M30?
    Not very useful if you want to limit for turning at one speed and for cutoff at another.
  18. #18
    Apr 2005
    Willoughby, Ohio
    428
    Post
    You can always set parameter 1202 bit 2 to a "0" if you don't want it to throw the alarm.
    Check to see if that bit is a "1" now (bit 2 is the 3rd bit from the right). If it is a "1", set it to zero and then just be careful to not try to use G50 to preset the coordinate system when in G54. Using G50 to set the spindle speed limit should never be a problem, even in G54.
    Did you try running your program with the G50S3600 block ahead of the G54 block ?
  19. #19
    Nov 2005
    1,486
    11
    148
    Post
    I took the G54 out becuase it really doesn't need to be there becuase i am only using one tool and just set the ofsets that way...
    Works without the G54.
    Thanks for all the help.
    Husker
  20. #20
    Aug 2002
    West Unity, Ohio
    23,112
    3418
    6394
    Post
    M13 is spindle on ClockWise/coolant on.
    Error should be in the line after it stops. At least on the 18-T. I have a 21-I too - but can't say 100% for sure on that one. ???
    Think Snow Eh!
    Ox
