zgoo
Hot Rolled
- Dec 10, 2002
- Portland, Oregon
I need help on what would be the best way to machine these parts;
They are made from 316 SS bar stock 1" dia. The length needs to be 2" with a flat .5" radius on one end. There is a turned step down on the other end of .100 and 3/4" long from the end. I also need a slot about .375 wide and.750 deep coming in from the top of the radius in the center of that end. I need to make 50 to 100 at a time. I have a CNC bridgeport knee mill. A cnc shop gave me a price of $13.50 ea T&M and that seemed a lot to me. Since I'm a new to this I willing to learn from you guys? I was thinking that I could take some 1" x 3/4" x 16" plates and put 4 of them against each other and make .800 holes every 1 1/2 along where the plates meet so that I can hold about 20 of the 2" parts standing on end and clamp the set on the mill table. Then using a ball mill cut the .5 radius in the tops by make long passes cutting each part in a pass until the radius is cut. Them cut the slots with end end mill at ringle angle to the radius. Any help with this or comments? How hard or slow will 316 be to machine?
Thanks-Dan
Thanks-Dan
