I am quoting a job that requires 18 cubic inches of material to be removed from a pocket with several posts.
I am having some trouble finding conclusive information about Inconel 600.
INCONEL® alloy 600 (UNS N06600) Ni 76.0, Cr 15.5, Fe 8.0 Description
The above link has sfm at 125 which appears to be higher than some other places I have looked. the same link has .007 per tooth feed.
I know Inconel has a tendency to work harden so it makes sense to take a healthy cut but that seems excessive.
I plan to use Imachining on this part. I was planning on using .5in 5 flt AlCrN coated cutter from Garr.
Are these numbers way off or should I trust them?
