Oldnewguy
- Jul 29, 2011
OK, I give up and hope y'all have a better answer(s) than I got. I am building a tightening fixture for my various iso20 tools and want to have the guy cut a taper in the base plate with the same angle as the tool holder. According to Machinery's Handbook and every other legit source, the taper is 3.5 inches per foot, and known as 7/24 for 7 inches taper in 24. Unfortunately, when I trig out that triangle, I come up with anything from 16.26 to 18.43, both of which are too steep. Is it maybe half that angle for some reason? I used MH formulas and Engineer's Edge online calculator and got diff results. I figure the rate should be .291667 per inch based on 3.5 inches per foot. Thanks for any help!
