slowtwitch
- Aug 9, 2006
- just north of philly
Hello Folks, I finally got my Fadal 3016 running (on single phase) and couldn't be happier. What a difference it is jumping up from a hobby type mill to an industrial machine. Simply amazing !!!!
Let me backtrack a bit and bring things up to date. I purchased the Fadal in January. I have since replaced the X ballscrew ( it had over .004 backlash), replaced all the thrust bearings and seals, on all the axis. The machine now has a backlash of ,0002 on X, .0003 on Y and .0000 on Z. Then it took me a bit to get my head around the 88HS control, the Renishaw probe setup and to workout the rs232 stuff.
But, all that is behind me.... Last weekend, I finally made my first parts. I was happy that the Fadal made them without a hitch. But, I was kind of disappointed at the side finish on the parts. I had my suspicions and they were confirmed after I indicated the runout on my holder. The end mill is a YG .375", for aluminum. The set screw holder was from Shars. The runout I measured was just about 5 thou. Last night, I install the same end mill into a Maritool .375 set screw holder and what a difference !!!! I was measuring under .0005" !!! I'll have to check it with the B/S (.00005")indicator tonight and see what the thing really is. But, I did a test cut and what a difference...The finish was like glass...it nearly brought a tear to this old man's eye...lol.
So lesson learned... buy good holders !!! I'll use the Shars holders (I only have three of them) for rough cuts. But, I'll be replacing them with good holders eventually.
Take care !!!!
pete
Take care !!!!
pete
