GP Tech
Cast Iron
- Jan 23, 2015
- Port Macquarie, Australia
I spent some time today checking the backlash on X and Y and found that the X axis is jumping .040mm when making .001mm adjustments with the handwheel back and forth.
I checked the backlash with MDI program of G00 G91 X50.; X-50.; Zero dial gauge Z50.;X-50.;X50.;Z-50.;
Backlash comp on X needed to go from 2 to 3 and Y had to go from 5 to 1.
I haven't worked how I'm going to check Z yet, I'll ask that question in another post.
I think this is a servo tuning issue, but I'm guessing and I can't find any info on how to tune the servos.
Also, how would I check the mechanical backlash? should I use a pry bar to get some back and forth movement?
Thanks for any help.
