Hello all!
I am trying to get a CNC machine at my work up and running, and this site has already been a great help so far. The machine is pretty ancient, a CompuMill 4000 controlled by a Dynapath Delta 20 controller. Its isn't used that often but could be if I could get it going. I have read many posts on the controller, while reading the manual that came with the controller, and I still cant get this darn thing to work. So here is my problem.
I put together the 25-9 pin connection per a post on this site, and it seems to work great. I tested it by writing a dumb program on the controller and sending it to the pc and it worked! I have a part I need to machine, which requires many holes drilled in it. I have used G-Simple to model the blank and have added four drilled holes (much more are needed, but for simplicity I used 4). I have produced the g-code with G-simple, unformatted is as follows:
O1001
(G-Simple, Version 2.05)
(Created: Wed May 27 09:39:39 2009)
N4 G54 G90 G98 G20
N5 T2 M06 (.116" Drill)
N6 S1000 M03
N7 G43 H2 M08
(DRILL ID 5)
N9 G00 X4. Y1.
N10 S1000 M03
N11 G00 Z0.9843
N12 G83 R0.1 Z-0.25 Q0.174 F20.
N13 G80
(DRILL ID 4)
N15 G00 X3. Y1.
N16 S1000 M03
N17 G00 Z0.9843
N18 G83 R0.1 Z-0.25 Q0.174 F20.
N19 G80
(DRILL ID 3)
N21 G00 X2. Y1.
N22 S1000 M03
N23 G00 Z0.9843
N24 G83 R0.1 Z-0.25 Q0.174 F20.
N25 G80
(DRILL ID 2)
N27 G00 X1. Y1.
N28 S1000 M03
N29 G00 Z0.9843
N30 G83 R0.1 Z-0.25 Q0.174 F20.
N31 G80
N32 M09
N33 M30
I understand the procedure to transmit the data on both controller and pc ends, and have all of the settings matching:
baud - 4800
stop - 1
bits - 7
parody - even
xon/xoff
I have tried to transmit the code using NClite and CNCconnect, and in both cases the programs show no problems. Each shows 100% transmitted and there are no errors on these pc programs. As I load the g-code the controller cycles through LOADING - N## all the way until the last line of code. The problem I run into is that the controller always stops at the last line of code and displays LOADING - N##(last line) and stays there and never displays DONE.
I have gone through and changed so many settings to try and fix this problem that my brain is numb and I need help. Hopefully someone can help me out! Thank you for your time!
Josh
O1001
N4 G54 G90 G98 G20
N6 S1000 M03
N7 G43 H2 M08
(DRILL ID 5)
N9 G00 X4. Y1.
N10 S1000 M03
N11 G00 Z0.9843
N13 G80
(DRILL ID 4)
N15 G00 X3. Y1.
N16 S1000 M03
N17 G00 Z0.9843
N19 G80
(DRILL ID 3)
N21 G00 X2. Y1.
N22 S1000 M03
N23 G00 Z0.9843
N25 G80
(DRILL ID 2)
N27 G00 X1. Y1.
N28 S1000 M03
N29 G00 Z0.9843
N31 G80
N32 M09
N33 M30
baud - 4800
stop - 1
bits - 7
parody - even
xon/xoff
Josh
