Kitamura H400 with Fanuc15-Mcontrols
Results 1 to 5 of 5
    Dec 2017
    Georgia
    Default Kitamura H400 with Fanuc15-Mcontrols
    Looking for help.New to the fanuc control on this machine.So go easy on me .I stopped machine while drilling to clear some chips I hit the reset button .So i figured i would just start at beginning of pallet one.I Get it to start prog and come in to z.1.Thats all it will do .Stops on the sub program that ive been running.Im a haas guy thrown into this so any help would help me since it will be 4 days to get anyone out here Thanks
    Sep 2008
    Florida
    341
    27
    87
    Posting code would surely help...
    Dec 2008
    New York
    8,313
    2208
    Quote Originally Posted by cwarriorc View Post
    reset control normally goes to defaults
    G54 work coordinates if you use G55 thats a problem
    G17 if you are not drilling in Z thats a problem
    G40 tool dia comp off
    D0 normally no tool uses D0
    G49 tool length off
    H0 normally no tool uses H0
    G80 drill cycle mode off
    .....basically many ways to crash machine just by pressing reset
    also restart you need to turn spindle and coolant back on
    single block mode is useful on restarts. always watch modal settings
    usually program check screen or program monitor screen list what modal commands are in effect. it might go by different names but program check screen it usually most important to watch that and distance to go
    Dec 2017
    Georgia
    Well heres my solution after 3 days Thanks for the input .I wrote another prog of my own and put in the other guys sub Machine ran fine called up sub and ran.So i switched back to his prog and still no luck .only7 one thing i didnt change out of all this was the prog got hung up on the G.1 feed move that had a M7 on the same line I change the M7 to M8 and its running like a friggin top I can not believe that was the prob but it worked?????M7 is thru spindal coolant because i have more of the on a couple tools and they run fine.Banging my head agaist the machine might have he;ped also .Thank for the input
  5. Likes Garwood liked this post
    Dec 2017
    Georgia
    So im back with a little more info on this.Machine ran fine then messed up on another tool at another m7 after running a few days .WTF i thought .Then i remembered a thru spindal Haas i ran was acting up like that.Da chips was causing a back pressure and not allowing tool to countinue on .So i hope someone needs to use this to their advantage .
