Perry Harrington
Titanium
- Oct 7, 2006
- Klamath Falls, Oregon
I've been meaning to post this once I had some pictures, Gismo's post prompted me to do it anyway.
My Haas VF0 always had lackluster coolant pressure, not enough to blast the chips away. I thought there must have been crud in the manifold, because it would seem to be an extreme oversight otherwise.
So I pulled the coolant manifold off the machine and inspected it, what I found was the loc-line nozzles were protruding so far into the manifold that the first nozzle was obstructing the galley to the others. I trimmed the threaded portion back to eliminate this obstruction, it improved the flow, but I thought it could be improved.
I examined the copper coolant hose that feeds the compression fitting on the coolant manifold and found it to be 3/8 ID. The compression fitting and manifold galley were no bigger than 11/32, which seemed to be a waste.
So, I grabbed a 23/64 and 3/8 reamer and reamed the fitting and manifold to 23/64 first, then 3/8 final. Now the fitting and manifold have the same area as the line feeding the coolant manifold, and boy does it work!
I've got 4 coolant lines with 3/16 holes drilled in the orifices and it sure blasts the chips away, no problems with coolant flow and chip re-cutting anymore! I'll try to put up some pictures and maybe a short video to illustrate the improvement.
Today I was running a bunch of 7075 parts, turning most of an 8.25lb block into chips, and they were all washing down off the table without any problems!
