Results 1 to 8 of 8
    Solar71 is offline Titanium
    Mar 2005
    Hermosa Beach California
    3,625
    Post
    Hey all...
    We are getting a laptop... Sweeet!!!!
    But its got ZERO serial ports... Its a new one...
    So with a USB port, how do i get the information into the CNC machine with its serial port ?
    Also we are using older dos spftwre for file transfer...
    Will i need a newer windows based one ?
    Can you guys suggest a program for transfer and an adapter for the UBS please ?
    thanks a lot
    mroy0404's Avatar
    mroy0404 is offline Aluminum
    Mar 2005
    Sarnia Ont. Canada
    209
    Post
    Solar
    I had the same problem, and found an adapter (USB to RS 232) at radio shack. It comes with a driver.
    No problems so far with it.
    hope this helps
    rosie is offline Hot Rolled
    May 2006
    Wisconsin
    827
    Post
    I recently bought a usb to 9 pin rs232 at best buy for about $36. It works much better than the hub I used in the past.
    Rosie
    Joe788 is online now Titanium
    Apr 2006
    Westside of America.
    2,739
    Post
    On this same note, I just bought a new laptop with no serial ports. My Mastercam dongle is serial, and I'd rather not switch to a USB dongle.
    Anybody know if there's a USB-to-serial adapter that will work with a dongle?
    (It's the large serial port, however many pins that is).
    Boris is offline Titanium
    Oct 2005
    England
    2,877
    Post
    Hi
    Solar be aware that some USB-serial converters dont convert all the signals properly particually if you are downloading to a Fanuc machine and it needs the DTR/DSR signals (can be a pain on CTS/RTS too)
    Dan is the guy to ask since he's the resident communications guru
    Boris
    And alas my DNC software cant cope with a USB port
    PBMW is offline Titanium
    Aug 2005
    Bremerton, Wa
    2,445
    Post
    I bought one from Radio Shack that works fine with my Haas machines but I have not used it with my Fanucs.
    Joe, I think (but you need totalk to your reseller) that you are going to go to a USB dongle. They don't support the serial ones anymore.
    Mar 2007
    Hamburg, Minnesota, USA
    1,471
    Post
    PCMCIA to serial, it's the ONLY reliable way to go. Search sleezebay, they are there.
    Dave
    2kjettaguy is offline Cast Iron
    May 2006
    Millersville, MD
    269
    Post
    The one I got from radio shack goes from USB to RS232. I made a cable which goes from RS232 to DB9 (I think that's what its called. 25 pin?) Anyways, it works fine with my Fanucs. I had to figure out the cable configuration myself. What the setup guy left with me didn't work with this adaptor, and subsequently what the dealer setup didn't work either.
    My dad's a computer programmer and he wrote a little downloader program. Works like a charm.
    Evan
