I'm just trying to learn a bit more about chip conveyors, mostly on lathes since I never had to deal with those yet, I didn't find good videos/pics on the net.
How much fines makes it past them and into the coolant tank normally?(I don't do cast/brass/bronze thankfully) but I assume to clean/maintain them and the tank you have to pull a 8-10' long conveyor, from the end? I've seen no useful details in any sales brochures about that. What's the real space requirements?
Do they also drip much oil/coolant on the floor on the discharge end, or much of it going out with the chips?
I'm trying to figure out my space/shop layout, and if I should just skip that option entirely and put the $$$$ elsewhere. A couple models have rear discharge options, but more $$$$, though better access for where I want to put this thing. I don't really make tons of chips(ok a few tons/year), and some are definitely stringy, mostly stainless.I also need to be able to do fairly easy/quick material change overs, without much chip contamination between material types.
Any other issues or plus sides with conveyors I need to know? I don't expect to be running unattended stuff much, no barfeed.
For those of you with lathes without conveyor, I assume there's just a drip tray/screen that it all falls on above the coolant tank, just scoop them out?(from then end?)
On my mill I just have an auger that pushes them in a drip tray, but tiny fine chips is about all I make on it and they go through the tray holes and end up in the tank anyhow and I scoop them out of there once in a while, pita, kinda doubt a conveyor would be any better there. I need to fab something better this year.
anyhow, thanks for any info about these things.
