Hello
As a complete beginner with lathes I need some help with tooling setup.
I need to make some simple 8" long aluminum rods with internal threads in both ends.
First I will turn the OD with the stock clamped between chuck and tailstock.
Then I want to drill and tap one side. Turn the part and drill/tap the other side.
My lathe has a 3 jaw chuck. Turning the outside won't be a problem.
But I'm sure I will damage the outside of the part when I need to clamp it for the holes/threads.
So what's the best approach and maybe the fastest when swapping parts/stock?
Buying a 8C collet chuck?
I don't have a pneumatic/hydraulic chuck or anything.
My idea was to program a G0 at the end of one operation. Then I can open the chuck, flip the part and push the part against a tool or flat surface on the turret for easy alignment.
