Scott H
Cast Iron
- Dec 2, 2001
- Covington, VA
I drill alot of holes on my Fadal. 1/4" 2-2.5" deep in mild steel. I am running it at 1750 rpm 10 ipm and go 2.25" in 3 pecks. I am looking at putting the Lightening Cool TSC system on my mill and using the coolant through drills. Has anyone here retrofitted a Fadal with the Lightening Cool system? For the guys that have TSC, what would you run a coolant through 1/4" drill at? What is the minimum pressure that I should use with a TSC system? Is the hole quality better?
I do also use smaller drill and have had to use a .125" drill 2.5" deep.
Scott
Scott
