Hello all, first post here.
I'm designing a jig for leatherwork that requires several very accurate holes, around 1.5mm in diameter and around 30mm deep.
I could use plastic or metal for the jig, and I'm looking for opinions on the best type of material/drill bit setup for this job.
The accuracy is absolutely key, so I can't have any drill-bit wandering. Open to suggestions!
Thanks in advance for any help you can offer.
