Mud
- May 20, 2002
- South Central PA
Lots of 7/8" holes in aluminum
I need a new tool for drilling shallow .875 dia. holes in 6061-T6. We've been using an Iscar Chamdrill, now I'm looking for something faster. The holes are through .500 to 1.0 thickness, we're drilling from solid, the diameter tolerance is +.005 - .000. We need a decent surface finish on the finished hole without a secondary operation. No spec, just has to look ok to us. Right now the Chamdrill is running 1800 rpm and 33ipm because any faster causes lots of squealing and chatter. What are you using in similar operations? I have 25 hp, up to 10,000 rpm and low pressure (200 psi) TSC. Drilling 36 holes per cycle.
