Mach3 Z-height macros - Where to start??
Results 1 to 9 of 9
    Jan 2013
    United States
    57
    6
    Default Mach3 Z-height macros - Where to start??
    Hi, very new to the biz. I've been making small tools on a 7x10 lathe for about a year now. Just three simple operations: face, center drill, and part. I've gotten my hands on a tormach 770 and want to speed it up!
    What I've done is put a collet fitting the stock in spindle and installed a pneumatic drawbar, so swapping out stock takes about 4 seconds. The tools are mounted on the table and ready to go. The one problem is the height.
    The collet grabs the stock and pulls it up to a non-repeating position. A friend pointed me in the direction of z-height macros, but I've had no luck finding the info needed to write the code, where to put it, etc.
    With that, I can load the stock, then touch the tip to a sensor pad and have the program run from there with all the correct offsets.
    Any tips, info, code, or where to look next would be highly appreciated!
    Mar 2002
    Brisbane, CA, USA
    1,671
    73
    192
    You'll get a better response to this question on one of the forums that have lots of Tormach users. There is a Tormach forum on Yahoo but the most active one is on a forum that the owner of this forum doesn't liked mentioned here as in the past they were apparently grabbing content from this forum without permission. But if you do a search on Tormach you should hit posts from these other forums.
    Jan 2013
    United States
    57
    6
    Ah, okay, thanks! Not much Mach3 stuff on here?
    Oct 2006
    Boston,Mass.
    1,973
    69
    163
    Quote Originally Posted by GDO View Post
    Have you thought about boring out a collet with a small step to act as a stop...
    Feb 2007
    New York City
    193
    9
    16
    Quote Originally Posted by BOSTON View Post
    or using a collet stop 5C Collet Stops, for milling machines
    Jan 2007
    s w NH
    191
    124
    62
    when i use the cnc knee mill to turn with, its generally using an er 32 collet holder with nut. the matl goes in just barely hand snug and sticking out too far. push the button, machine travels to a flat surf on the vise near the 1st turn tool, then feeds quickly in z down pushing the matl up into the collet, and stops. i grab the spanner and tighten the nut. push the button again and the cutting cycle begins.
    Feb 2007
    New York City
    193
    9
    16
    I didn't realize this was turning in a mill. I like the above suggestion.
    Oct 2006
    Boston,Mass.
    1,973
    69
    163
    Quote Originally Posted by will gilmore View Post
    That OK...We folks in Boston are use to you guy in New York City mouthing off without knowing what the conversation is....just kidding
    GO RED SOX...
    Jan 2013
    United States
    57
    6
    Thanks for the ideas guys! I'm off to go bore out a collet and give that a shot. Still will need that code eventually, but I understand this forum may not be the place to ask.
    Thanks again!
