gakor
- Feb 10, 2008
- Canada, BC
Hello,
I wonder if you guys could be kind enough to share your experience machining nylon. I have 20,000 bushings to cut. The bushing is 9mm long +/- 0.1, 10mm OD, and 6.6 +/- 0.1mm ID. I have never cut nylon before. I would appreciate a heads up so I have some time to prepare. What inserts would you guys reccomend? What brand? What feed, and what speed?
Customer supplies solid rods, so I have to drill. What drill would be suitable to do the job quickly and leave a nice finish?
I think they mentioned the nylon type to be LC94, PAS. This is not for sure, though.
Thanks ahead.
Thanks ahead.
