Ox
- Aug 27, 2002
- Northwest Ohio
Never touched the stuff before, so took an opportunity to play with it.
However - the print has changed since I quoted it - and for one thing - it needs heat treated.
Voice says that it is "5706" right now = RC-35
But the print has been updated to "5707" which he says will come in per the cert to RC-42
I thought that this stuff was gummy?
Apparently not...
From my experience, I wouldn't think that those 7 points wouldn't make much difference to me - and would prefer to H/T prior to machining. But with no experience in this material - I am checking with y'all.
I am turning round bar down (short stubby) and milling the flanged end flat. Possibly in the lathe.
I think the bar is 2-1/2" round.
Dare I expect to be able to cut it off in the lathe, or should it be slugged up in the saw first?
I found threads on the stuff as far as S/F / DOC and whatnot, but no clue on the "part-off" opperation at all. That is a pretty deep cut. I could stagger it and work my way down tho...
Only have 16 parts to make.
Most of all - currently - I need to decide if I want to have it H/T'd first or not.
Oh yeah - I need to put a 1/4-28 in 1/2" deep.
Can I form tap that? Or will I need to mill it in?
Thanks Y'all!
Ox
Apparently not...
Thanks Y'all!
Ox
