Hi Guys,
We have an ongoing job, a trunnion. Attached drg & images. Highlighted Outer profile needs change in machining. Right now its being done conventionally -- roughing out with Indexable endmill; several passes and finishing with Solid Carbide Endmill.....Takes hell of a time.
I was thinking to change the method of machining this outer profile. If mounted onto 4th Axis Side-ways, I was wondering if we can machine it along Y-Z Plane with Y-Z and Rotary A-axis all working simultaneously. Have seen couple of videos doing the same.
Any help will be greatly appreciated. Stock is not much and entire profile is easily doable with a 63mm Facemill that we have.
