Omniturn CAN Cycle ( what the hell )
Blobis
Aug 15, 2017
Hello everyone, I've been programing Okuma mill and lathe for more than 15 years now and this Omniturn G4 manual is killing me, figured everything out so far, but the damn CAN cycles I just don't get it. I want to rough something out and then finish with another tool using the same geometry. Can anyone out there explain it to me better than the book? Or maybe I've reached the end of my learning capabilities.
Thanks, Bob
Does it have anything similar to Fanuc G71, a rough turning cycle (which I call multiple turning cycle, to differentiate it from G90 which is a single turning cycle)?
I can sympathize with your feelings about the Omniturn manual.
What specific issues are you having with the can cycles? From my experience with the G3 control they work but maybe not the way you're used to.
RT
You are describing the exact reason, shortly after I got my used Hardinge/OmniTurd machine, why I ended up removing the control and installing a Fagor 8025 on it. Frustrating is an understatement.
I put the OmniTurd control on EBAY and sold it for nearly what I paid for the whole machine. 2 months later the EBAY buyer messaged me and asked if I wanted to buy the control back at his substantial loss.......I declined! My thoughts are that whoever developed the OmniTurd software must have never run any cnc machines. It's far different from any other cnc controls.
Thanks, Bob
I want to rough out with certain geometry with one tool, them come in and finish with another tool. Trying to use G75 or G78.
It says in the book I need to make the geometry a subroutine then the next tool will do the finish pass, but the program examples are very vague. Do you happen to have a program example I could look at to see how it's actually written? Any help would be great.
Thanks, Bob
What you want is, of course, possible on all controls.
Possibly on your control also.
Please post the examples, along with the figures, from the book which we can try to interpret.
N1
(OD ROUGH TURN CYCLE)
(SAFETY LINE BELOW)
G00 G54 G18 G40 G80 G97 G99
T101
G54
G50 S2000
G97 S800 M03
G00 Z3.
G00 X64.1
M08
G96 S450
F0.096
G00 Z1.
G01 X-0.4
G00 Z1.5
G00 X64.1
G00 Z0.5
G01 X-0.4
G00 Z1.
G00 X64.1
G00 Z0.
G01 X-0.4
G00 Z1.
G00 X64.1
G71 P2518 Q2519 D1. U0.25 W0.025 F0.125
N2518 G00 X55.
G01 Z0
G01 Z-1. X57.
G01 Z-12.
G01 X60. ,R0.35
G01 Z-18.
N2519 X64.1
G00 Z3.
G97 S800
M09
G00 G53 X0.
G00 G53 Z0.
M05
(END OD TURN CYCLE)
M01
N2
(OD FINISH TURN CYCLE)
(SAFETY LINE BELOW)
T202
G54
G50 S2000
G97 S800 M03
G00 Z3.
G00 X64.1
M08
G96 S450
G70 P2518 Q2519 F0.076
G00 Z3.
G97 S800
M09
G00 G53 X0.
G00 G53 Z0.
M05
(END OD TURN CYCLE)
M01
This is how I do the Rough and finish with two tools,
remove the G70 from the first canned cycle and write a new cycle below it with only the G70 in it
This is how it is done.
But what do you mean by "remove the G70 from the first canned cycle and write a new cycle below it with only the G70 in it"?
G70 is not used inside G71.
N1
(SAFETY LINE BELOW)
T101
G54
G50 S2000
G97 S800 M03
G00 Z3.
G00 X64.1
M08
G96 S450
F0.096
G00 Z1.
G01 X-0.4
G00 Z1.5
G00 X64.1
G00 Z0.5
G01 X-0.4
G00 Z1.
G00 X64.1
G00 Z0.
G01 X-0.4
G00 Z1.
G00 X64.1
N2518 G00 X55.
G01 Z0
G01 Z-1. X57.
G01 Z-12.
G01 X60. ,R0.35
G01 Z-18.
N2519 X64.1
G70 P2518 Q2519 F0.076 <---- this is where I normally put it if I'm roughing and finishing with the same tool
G00 Z3.
G97 S800
M09
G00 G53 X0.
G00 G53 Z0.
M05
(END OD TURN CYCLE)
M01
my apologies sinha, I didn't quite phrase it right the first time round
Thanks, Bob
Blobis,
Have you successfully used G75 and G78 without using the subroutine option? Can you post your code?
RT
Example codes from the manual also need to be posted. Then only, one can try to understand how they do it.
