Macro Programming Fundamentals - Page 2
Page 2 of 28 FirstFirst 123412 ... LastLast
Results 21 to 40 of 553
  1. #21
    May 2004
    Zellwood, Fl.
    1,440
    586
    279
    Macros and sub programs gotta love them and I wish I was a bit better educated in the use of macros but then I would not have to reason to ask a question. Here goes I currently have setup a main program to run part programs with looks something like this:
    O12
    (MASTER PROGRAM)
    (MODIFIED: 06/28/05 REV B)
    #2=1(SELECT TYPE =1 NEW =2 OLD)
    #1=1(ENTER NUMBER OF PROGRAMS)
    IF[#2EQ1]GOTO10
    IF[#2EQ2]GOTO20
    GOTO100
    N10
    IF[#1LT1]GOTO100
    IF[#1GT4]GOTO100
    (*********** PROGRAM 1 ***********)
    G65P9010W54(ENTER WORK LOCATION)
    M198P21502(ENTER PROGRAM NUMBER)
    IF[#1EQ1]GOTO100
    (*********** PROGRAM 2 ***********)
    G65P9010W40(ENTER WORK LOCATION)
    M198P393759(ENTER PROGRAM NUMBER)
    IF[#1EQ2]GOTO100
    N100(END PROGRAM)
    G10L2P1X0Y0Z0B0C0
    GOTO999
    N20
    G90G80
    M14
    G00G53Z-15.
    X10.B0.C0.
    G90G80
    G5.1Q1R1
    M14(TABLE)
    G55(OFFSET)
    M98P92(PROGRAM)
    G53Z-15.
    G53X10.Y50.
    M05
    N999
    Then I use the header in the part program to relate work coordinate something like this.
    O3000
    G65 P9011 (PARK POSITION OF MILLING HEAD)
    G5.1 Q1 R1
    G65 P9010 W11 (WORK COORDINATE CALL)
    P9010 (WORK COORDINATE LISTING)
    O9010(SET WORK POSITION)
    IF[#23EQ11]GOTO11
    IF[#23EQ12]GOTO12
    IF[#23EQ13]GOTO13
    N11(M15)
    M15
    G10L2P1X15.45Y10.23Z-47.17
    GOTO999
    N12(M14)
    M14
    G10L2P1X15.45Y70.23Z-47.17
    GOTO999
    M30
    N999
    M99
    Now what I would like to do is set up the same type of call for tool length variables. The part I am not sure of is the syntax necessary to do this. Not real sure that
    P9015 (tool compensation listing)
    G10 L2 P1 H3 would work in the part program looking for
    IF[#23EQ11]GOTO11
    N11(T1)
    G10 L2 P1 H3= 3.25
    GOTO999
    Anyway hope this gets the idea across of what I am looking to do. And yes this is a mill as opposed to a lathe.
    Scott
  2. #22
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    Quote Originally Posted by scojen View Post
    IF[#23EQ11]GOTO11
    N11(T1)
    G10 L2 P1 H3= 3.25
    GOTO999
    Scott
    Basically, anywhere you can put a value (number) you can put a variable (#).
    You can go so far as to actually read out your tool length from the control via system macro and assign it to a variable.
    Here is one where I'm getting the tool currently in the spindle at cycle start, to make sure the correct tool is in the spindle...
    It's using tool groups (9xx), but would work the same for individual tools, provided your control has a system variable available for "tool in spindle".
    (O8011 INITIALIZATION SUB)
    N5 #800=#3700 (GET TOOL IN SPINDLE)
    N10 IF [#800 EQ 1] GOTO 400 (2.3 DRILL)
    N15 IF [#800 EQ 2] GOTO 400 (2.3 DRILL)
    N20 IF [#800 EQ 3] GOTO 400 (2.3 DRILL)
    N25 IF [#800 EQ 4] GOTO 500 ( END MILL)
    N30 IF [#800 EQ 5] GOTO 500 (.375 END MILL)
    N35 IF [#800 EQ 6] GOTO 500 (.375 END MILL)
    N40 IF [#800 EQ 7] GOTO 600 (BORING BAR)
    N45 IF [#800 EQ 8] GOTO 600 (BORING BAR)
    N50 IF [#800 EQ 9] GOTO 700 (3.0 DRILL)
    N55 IF [#800 EQ 10] GOTO 700 (3.0 DRILL)
    N60 IF [#800 EQ 11] GOTO 800 (BULL NOSE END MILL)
    N65 IF [#800 EQ 12] GOTO 800 (BULL NOSE END MILL)
    N100 GOTO 900 (ERR0R)
    N400 #801 = 901
    N405 GOTO 990
    N500 #801 = 902
    N505 GOTO 990
    N600 #801 = 903
    N605 GOTO 990
    N700 #801 = 904
    N705 GOTO 990
    N800 #801 = 905
    N805 GOTO 990
    N900 #3000 = 34 (LOGIC ERR 8011)
    N990 M99
    Now, I call the correct offsets for that tool before I do much of anything else....
    N26 G55 G0 X#590 Y0. Z200. G43 T#801 H#801 D#801
    In this one....
    I'm getting the tool life counter value from the control, and checking to see if the tool life is up. If the tool life is still good, I'm skipping the tool call.
    N401 #850 = #3700 ( SET #850 TO TOOL NUMBER )
    N402 #851 = [#850+5800] ( ADD 5800 TO TOOL NUMBER )
    N403 #852 = #[#851] ( SET #852 TO REMAINING TOOL LIFE )
    N404 #590 = #629
    N405 IF [#801 NE 901] GOTO 410
    N407 IF [#901 NE #900] GOTO 410
    N408 IF [#852 NE 0] GOTO 412 ( IF TOOL LIFE DOESN'T EQUAL 0 SKIP TOOL CALL)
    N410 G100 X#590 Y0. Z120. G43 T901 H901 D901 (TOOL CHANGE - DRILL)
  3. #23
    Jan 2007
    Ohio
    1,153
    Quote Originally Posted by Bluechip View Post
    QUOTE : "Bluechip, are you saying that the converter changes the Fanuc macro into a common variable program for the Okuma? "
    Yes ... CNC XChange will auto-convert all areas of the Fanuc Macro B language including Common Variables, System Variables, Arithematic Operations, Control Commands ( While / Do loops, If, etc., Conditional Expressions ( EQ, LT, etc. ) ... into the compatible Okuma User Task commands / variables ... and REVERSE.
    CNC XChange also has an unlimited user defined area where users can set-up their own "what-to-convert-into-what" in case their control does some specific functions not covered in the hard-coding.
    Of course .. our standard version of CNC XChange will also convert standard Fanuc G code to Okuma OSP code ... and REVERSE.
    Again ... info and video presentations at www.KentechInc.com
    Have you tried to sell to MasterCam? Seems as if they and Okuma have a communication problem, and I don't mean from CPU to contol. Possible to get a copy sold per MasterCam rep and tech out there. Just a thought.
  4. #24
    Dec 2002
    Granville,NY,USA
    3,863
    258
    366
    Quote Originally Posted by Tonytn36 View Post
    I like the looks of this. Very much like the H&T agreement setting in the Haas control.
    Thanks again Tony for sharing your knowledge in an easy to understand way.
  5. #25
    May 2004
    Zellwood, Fl.
    1,440
    586
    279
    Tony,
    Thanks for the explanation, but I do have a question is there a difference between calling a tool from an existing register and assigning a value to a tool thus changing the value in the register, which is really what I would like to do. Reason is I have programs that use the same tool but the tool length may change from part to part.
    Scott
  6. #26
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    scojen,
    Get out your macro programming book for your control. You should be able to write to the offset register, as well as read from it. You are looking for the system macro values for the tool offsets. It will tell you if you can write them or not.
  7. #27
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    Tony,
    Scott
    Scojen,
    As an example, lets look at a Fanuc 16-18-21 series control.
    From the table in the operating/programming manual, for a mill, the control uses the table: compensation memory 3 (H,D).
    In this instance,
    OFFSET Comp Amount(H) Wear(H) | Comp Amount(D) Wear(D)
    NUMBER Variable Variable | Variable Variable
    1 #11001 #10001 | #13001 #12001
    999 #11999 #10999 | #13999 #12999
    These can be written and read.
    You have another situation, if the control only has the standard 199 offsets, you can alternatively use the following:
    1 #2201 #2001 | #13001 #12001
    200 #2400 #2200 | #13200 #12200
  8. #28
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    Default Finally time for another post
    Ok, where were we?.. It's been a busy couple of weeks... oh yea, calculations...
    (Btw, if I screw this up, someone let me know, I'm doing this "off the cuff" as I go, and I've got a "cold from hell". It won't go away , and I've been up since 2:30 am because of it.)
    So, we have determined that the number of holes is either even or odd in the previous post. Now we do a couple of the more simple calculations:
    #603 = 360/#500
    This result gives us the number of degrees between holes which we will need later.
    #604 = #501/2
    This result gives us the radius of the BC which we also need later.
    NOTE (Outtake):
    We'll put all of this stuff in and in order in some semblance program later. What I do to make things easier (and maybe you can see why later on), is to break the job down into little jobs, just like a machine set-up.
    In a machine set-up, you are typically going to look at the print to get an overall picture of what you are making. Then you are going to look closer, and determine what tools and materials you need to make the part. Then you are going to look at how to fixture the part for each operation. The final step before actually cutting chips is to determine in what _order_ you are going to perform the different operations.
    Programming is the same way, you look at the overall functionality you need (picture), then the calculations, routines, etc (Tools & material) you need to do the job. Then you write each little segment (fixturing), and finally, you put them all together with the logic to make them work (order of operations).
    And now, back to our regularly scheduled programming:
    We will need to determine if a hole starts on the 0° machine axis.
    IF [#502 GT 0] GOTO XXX
    This says "If our start angle is anything but 0°, we'll go to our non-zero start angle calculations.
    Using the first calculation we did in this post, we need to get our trig components. I just do all three as a matter of course, even if one won't be used. If I happen to later decide I need one, I already have it.
    #605 = TAN[#603]
    #606 = SIN[#603]
    #607 = COS[#603]
    NOTE (Outtake #2):
    I keep a spreadsheet (excel or OO Calc), with a list of all variables. I use this to identify what variable is assigned to what for each program. I am attaching a sample spreadsheet in both *.ods and *.xls format (see zip file).
    Til the next post.....
    Safety tip of the day:
    Never turn your back on a machine - It keeps the hot chips out of the crack of your ass....
    Attached Files Attached Files
  9. Likes Road HOG Mill liked this post
  10. #29
    Mar 2007
    MA.
    103
    Thumbs up Great thread Thank you !
    Tony thanks for starting this thread, and thanks to all who have contributed ! I don't use Macros enough to contribute but I'm really getting a lot out of this. Thanks for taking the time.
    regards,
    Dick
  11. #30
    Feb 2007
    Worcester, MA
    9
    Exclamation Warning on look ahead on Fanuc 30 series controls!
    If you guys have parameter 1604 bit 0 set to a 1 - Which enables high speed machining mode automaticly in feed or plan to use macro statements in high-speed machining modes, the look-ahead of the control will process macro statements WAY ahead of the actual block of code you are running. Which can give some interesting and annoying results! The Robodrill and Matsuuras (and I believe all Fanuc 30 series controls do this) I work on we use "G5.1 Q0" to suspend automatic high speed machining. The Siemens controls have the "STOPRE" command to stop pre-processing so the look ahead doesn't turn your macro logic into mud!
  12. #31
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    This is very true Noah888. If the control doesn't have the stop pre-processing commands, you can use blank blocks to do it.
  13. #32
    Jan 2003
    Tel Aviv, Israel
    493
    61
    79
    Default Look ahead (buffering) problem
    Quote Originally Posted by Noah888 View Post
    The look ahead (buffering) problem exists on 16, 18, 21 and newer controls regardless of using or not using the high speed machining. The G53 command or dedicated M functions (parameters 3411-3420) prevent buffering.
    Probe
  14. #33
    Dec 2007
    Southeastern US
    6,254
    749
    2623
    Just an update note, I've finally got some time off (10 days worth ) so I should be able to get some more stuff down on screen, in between the must-do's already planned.
  15. #34
    Sep 2006
    Long Island, New York
    505
    113
    58
    Thanks for this thread Tony!
    I have a Fanuc 11M here and I would like to make a simple parts counter. I can't figure out where these variables are stored. Is it somewhere in the menus after hitting the NC/PC button?
  16. #35
    May 2008
    Great State Of Wisconsin
    444
    5
    They shold be listed under your Settings button labeled (variables/common variables). Not 100% how to get there on the 11M control but if you press your settings key you should be able to over arrow until you see options like Offset/Macro/Tool ect. should be under macro. You also might just have to press the settings until they are displayed.
    Stevo
  17. #36
    Sep 2006
    505
    113
    58
    Found it, thanks. I had the wrong book out.
    The page for macro variables just says "No Option" and I can't get any values to come up. Same thing with a "Tool Life" page. I assume that means those are options not bought with this machine?
  18. #37
    Nov 2004
    WI
    4,577
    369
    1017
    Understanding "Vacancy"
    There was yet another excellent article this month by Mike Lynch on Macro programming.
    Here he describes when variables are not initialized, they are not equal to zero, they are in fact "vacant" and do not contain ANY number. There is a an easy test for "vacancy"
    This is useful if you have a subroutine that you can pass variables to. If one of the variables is not used, it is vacant, and your program can ignore that "option" or use a default setting.
    I can post an example from on of my own programs later..
    Here is this month's article.
    http://www.mmsonline.com/columns/und...g-vacancy.aspx
  19. #38
    Apr 2009
    Michigan, USA
    Default 12 hole bolt circle with each hole 30 degrees Apart
    My friend has a shop with a Monarch CNC milling machine and needs code for a bolt circle with 12 holes 30 degrees from each other. Could someone suggest how to code this very simply?
  20. #39
    Jul 2006
    Clover Hill district, WI
    2,304
    7
    Default Wow , what a thread.
    I have to get with the program.
    Thanks Proffessors!
    M1M
  21. #40
    Jul 2006
    2,304
    7
    Hi!
    On a ? 1996? or so Mitsubishi Bar,
    with a little Mitsubishi control.
    Small mono skreen but newer keypad.
    The darn kind where the charactors on the buttons wipe off over time.
    Some of the bars I have used had a M6 call a complete macro(correct?).
    Just T4 M6 .
    Others ya had to type all the comands.
    Also for the 'B' axis a G100 (a macro true?) on some;
    G100 B180 * degrees being absolute or incremental depending on the shop.
    Others ya had to do the M11's & M10's.
    How can I tell if this mill.....
    (I don't think they have gone beyond powering it up)
    Has Tool-change & B-rotate as macros?
    That is without just trying it.
    And if not I will want to install such macro's.
    Pardon my ignorance, usually this was all done
    before I was involved.
    Thanks kindy
    if ya can help.
    M1m
