meandean77
- Jun 23, 2014
- United States
** i need help** KIRA KNH-40HB (300MM HMC) Fanuc 21i** I was dnc'ing the other day and the computer power supply had an issue and decided to shut down, obviously the machine stoped cuz it was waiting for code. No problem, I modify the program to start at the tool that was in the spindle, after fixing the computer power issue, easy stuff. But now I have a major problem that I can not figure out, neither can machine service department. Machine is 300mm HMC with Fanuc 21i controller. Ever since the pc/DNC issue my dynamic work offset macro is not calculating correctly, I have confirmed that all variable values are correct that are used in the dynamic work offset macro, the problem occurs wen these values are calculated in the couple trig equations at the end of the macro. The part program is proven over a thousand parts, the dynamic work offset macro is proven, been using it for several years, problem only started after the computer shut down, mid DNC ** I'm stumped. ANY IDEAS???
