twmcree
- May 9, 2018
- Austin Texas
Hi all,
Posting in order to get a bit of advise - any suggestions welcome.
Thank you for your time & input, in advance.
So after quite a bit of research, it looks like a fadal 4020 extended-z is the machine for the job. Capacity is the driving factor here, not speed/production rates.
Looking to keep the initial cost of the machine down as low as possible. I have the time and means to troubleshoot, but limited capitol.
Also, what sources would ya'll recommend checking out for a machine?
Wagner
Job specific requirements:
-28" z-axis movement is important.
-slow rapids and tool-changes are fine.
-controller will be replaced w/linuxcnc and mesa i/o's to drive servos, spindle, & tool-changer.
-servos: either AC or DC will work.
-rigid tap is not required
-HT if possible.
-boxed ways.
-HT if possible.
-boxed ways.
Data gathered regarding what to watch out for:
-check turcite wear and scratches on ways.
Common procedure regarding transportation and initial maintenance
-rigging procedure specified in fadal tech docs.
-good idea to change out the bellevilles, and the drawbar floater prior to operation.
The IDEAL purchase so far would be:
-a box way machine that has good turcite - ways in good shape
-currently set up with a controller that has issues / or one of the less desirable controller variety.
Wagner
