Making a deep hole with good finish and accuracy
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Mar 2005
    India
    7
    Default Making a deep hole with good finish and accuracy
    I have to make a hole of Dia 13.5mm and 68mm deep in Aluminium 6082. The finish required is 0.8 Ra max.
    I am doing bigger holes on CNC lathe with carbide boring bars. But this one seems to be challenge as I will have to use a 8mm Carbide boring Bar would mean L/D ratio of 8.5 Times. This results in chattering.
    I am thinking of doing this hole on a VMC. But I am not sure about the tools to use! Maybe a Drill of 13.25mm followed with a boring bar. Or maybe a PCD drill?
    Wohlhaupter sales person is not confident that it is possible on their holders even with carbide boring bar and not not seem to have a solution.
    So I guess it may have to be PCD Drill.
    May 2005
    CA
    886
    146
    Use a larger boring bar or reduce the tip radius on the cutting edge to near nothing. Preferably both.
    Jun 2012
    Michigan
    3,515
    2896
    2030
    Is it a blind hole? Might want to try feeding left to right for the finish.
    Do you have the budget to buy a carbide dampened bar?
    Nov 2011
    UK
    112
    39
    18
    Slow the spindle speed down.
    Jun 2013
    Oregon
    971
    240
    566
    Positive rake insert = less cutting pressure.
    Apr 2005
    Beaverdam, Virginia
    5,714
    160
    2260
    I am lost here, it isn't even 10x diameter deep. Why not just drill and ream for the finish requirement?
  7. Likes yardbird, Limy Sami, apestate, Steveo, Hazzert liked this post
    Nov 2011
    UK
    112
    39
    18
    Use a 10mm boring bar. That needs a minimum bore size of 12mm so you have plenty of clearance.
  9. #8
    Jan 2007
    Norfolk, UK
    16,662
    12296
    11751
    Quote Originally Posted by Dualkit View Post
    That was my reaction, ......but I didn't post as the R word seems kinda dirty on the CNC forum.
  10. #9
    Jun 2015
    CANADA
    British Columbia
    1,040
    239
    545
    Very light cut on the finishing pass(es)?
  11. #10
    Aug 2003
    New York
    92
    10
    +1 for Gobo & precisionmetal
  12. #11
    Apr 2005
    Beaverdam, Virginia
    5,714
    160
    2260
    Quote Originally Posted by Limy Sami View Post
    You can ream faster than boring and you don't have to worry about galling in soft aluminum from chips getting packed around a boring bar. No brainer to me unless you are making a one off and you don't have a reamer in stock, but plenty of boring bars.
  13. Likes Limy Sami liked this post
  14. #12
    Jun 2002
    CANADA
    British Columbia
    2,124
    1408
    Hi matoind:
    I've seen some amazing results from bog-standard coolant through carbide drills...better for size control and finish than I would have believed to be possible.
    I'd talk to a Guhring technical sales rep and see if they can make a recommendation for you.
    Cheers
    Marcus
    www.vancouverwireedm.com
  15. #13
    Jun 2013
    Oregon
    971
    240
    566
    I gotta agree. It just seemed like such an obvious answer, I suspected a trap.
  16. #14
    Apr 2005
    Beaverdam, Virginia
    5,714
    160
    2260
    Quote Originally Posted by Gobo View Post
    Maybe the metric numbers have baffled some of the USA contingent here. It amazes me how many machinists can't convert metric numbers to inches in their head. The last place I worked for the man almost everybody but me had either a small calculator (most people didn't have cell phones then)or a decimal equivalent chart in their pocket.
  17. #15
    Feb 2014
    Sunny South West Florida, USA
    2,159
    8789
    2539
    .03937
    For rough conversions on the fly, I just use .040.
  18. #16
    Feb 2013
    Madison, WI
    615
    822
    358
    Quote Originally Posted by TeachMePlease View Post
    .03937
    I prefer 25.4 myself. To each his own.
  19. #17
    Nov 2002
    3,005
    1281
    635
    I would be leery of reaming the hole, IF you only have 1 shot at the part.
    Reaming is a crap shoot, at best, if you have no experience with the exact same part/material/tooling/ machining strategy, etc....
    Without notes or previous experience, I can foresee any/ all of the following:
    Bell mouthed hole
    Over/undersize issues
    retract lines (scratches) from the reamer
    wondering hole
    I love reamers, but when I NEED absolute control over a NEW process; always the boring bar.....
    To the OP, if you have some setup parts, and or some extra material, DEFINITELY try a reamer.
    Drill a 33/64" and follow it up with a LH sprial, RH cut reamer. If you can get coolant through the reamer, it will be a snap!
    Doug.
  20. #18
    Mar 2003
    Utah
    1,057
    51
    15
    hole is .5315" depth is 2.677", microfinish 125 ra.
    Buy a 13.1 drill if you're getting oversize holes. if not 13.2mm (.520) then ream it 13.5.
    buy a brand new chucking reamer and lovingly dull the corner at the chamfer with a "reamer stone" or equivalent
    Make sure drilled hole looks like 13.2mm
    Throw some of that green tapping fluid for aluminum on the reamer with an air gun
    ream it at 50 rpm and 15.25 mm/min (.012" / rev) feed
    increase feed rate & speed for a little bigger hole
    bore in - bore out, don't rapid out or you'll yank the part out of the vise
    and if the finish comes out ugly, have a 13.5mm ball bearing ready and press it through ...
    wait, is this a blind hole or thru hole?
  21. #19
    Aug 2002
    West Unity, Ohio
    22,858
    3236
    6255
    Finish is 32
    Is there a reason that you can't use a reamer? (BTW - that is 17/32 inche in Western civilization)
    Is it blind?
    Does it need to have sqr bottom?
    I for one would NOT go with a LH spiral reamer unless it's a through hole. (we are in the "CNC" forum, so I'm expecting that this is not a Manuel opperation that needs the LH twist)
    I also would NOT stand it up and bore it in a mill if it is blind.
    If a reamer is possible, I would use a floating holder to help it stay on size and negate those nasty pull-out marks that you were warned about prior.
    If you need a sqr bottom in a blind hole, I have had endmills altered with through coolant (apparently a "hole popper" is the ticket for this. Many folks with wire EDM's will have this.) The coolant through will help to flush the chips out. I have had good luck with this in 6061.
    disclaimer
    I have no experience (knowingly anyhow) with this flavour or alum.
    Think Snow Eh!
    Ox
  22. #20
    Aug 2004
    Arlington, TX
    169
    Drill, ream, and finish size and required finish with a roller burnishing tool.
