Manual chuck on CNC lathe?
Results 1 to 13 of 13
    May 2007
    lancashire, england
    79
    Default Manual chuck on CNC lathe?
    Hello there,
    We aquired a second hand Mori Seiki CL machine a few weeks ago. This is our 11th Mori so we are quite familiar wth how they work etc.
    The machine came wth a collet chuck attached and a bar feeder, whch we have been running for a few weeks,but we now want to put a 3 jaw chuck on the machine.
    The machine was delvered wth a ROTA-G 200-62 chuck. I have looked at these on the internet and it is described as a manual lathe chuck. It has no internal thread to screw it onto the machine draw tube,but can be screwed on to the face plate with 3 cap head bolts.
    The hydraulic pedals don't open or close the jaws because they are in no way attached to the drawtube, but instead the jaws are closed with a square key, just lke on a manual lathe, and move in on a spiral.
    I certainly don't lke the look of this, or the idea of usng it on the CNC machine, has anybody used one of these on a machine before,if so, did it work? I don't like the idea of the machine spinning at stupid revs, without hydraulics holding the job in the jaws.
    Aug 2002
    West Unity, Ohio
    23,121
    3433
    6405
    SURE DOO!
    On the real big girls all your gunna git is scroll chucks.
    For instance - I have a machine with a 32" three jaw Cushman scroll chuck. Now the machine does have a "power wrench" that is nothing more than a gearmotor with a special end on it to mate with the pinion on the chuck. There are also three trq settings as well - but once it's tight - it's tight. Machine will spin 800RPM with that chuck on it.
    Hydro can fail - although actuators have check balls (valves?) in them to resist opening from power failure - the scroll will not open w/o turning that pinion backwards.
    I have a sister machne with a 15" 6 jaw scroll chuck on it.
    I have a 12" scroll chuck that I will put on the smaller machines as needed.
    I don't know what to be scared of - other than change itself.
    Think Snow Eh!
    Ox
    Aug 2006
    Munith, Michigan
    2,080
    177
    451
    Ox,
    What machine are you running a 32" chuck on ???
    As far as the original question. Yes, I've seen quite a few large CNC machines with big manual chucks, so I believe that it is quite common.
    Frank
    www.randolphmach.com
    Oct 2005
    9,599
    16706
    4891
    We've got a local machine shop here that ordered a rather large (24" I think)
    Haas cnc lathe with a manual 4-jaw on it.
    As he explained, the work he does is very low volume (1-8 parts), for
    powerplant overhauls (time constraints) and the cnc is needed for
    the various contouring of the complicated parts.
    The cycle times are pretty long, the materials are pretty tough,
    the load/unload time is a very small percentage of the total.
    Feb 2006
    Republic of Texas
    2,252
    Bison 16" 3 jaw scroll chuck on a 24" swing lathe. 1800 RPM machine. Torque limited impact wrench. No problems.
    Feb 2009
    Vancouver, B.C. Canada
    1,816
    95
    Quote Originally Posted by turner13 View Post
    ....I certainly don't lke the look of this, or the idea of usng it on the CNC machine, has anybody used one of these on a machine before,if so, did it work? I don't like the idea of the machine spinning at stupid revs, without hydraulics holding the job in the jaws.
    Haas toolroom machines use manual chucks and we use either an 8" or a 10' on a Haas GT20 which works fine. It is possible you will need to derate your maximum rpm but maybe not depending on the rating for the manual chuck.
    I think your concern about lack of hydraulics holding a spinning chuck closed is misplaced. A hydraulic chuck can open at high revs because the closing system can back drive; it is only a wedge system and does not have any mechanical lock. A scroll chuck cannot back drive open due to centrifugal force.
    Mar 2006
    Columbus, Ohio
    1,107
    118
    Once you get to a certain size, the chucks are usually manual.
    Often they are 4 jaw chucks, because the parts need to be indicated.
    As far as I can see, they hold as well as any hydraulic, as long as you actually tighten them.
    Take a look at a nice picture I have on the website, we are making a oilfield motor housing on a large CNC lathe and we are using a large manual 4 jaw chuck.
    Heinz.
    www.doccnc.com
    May 2007
    lancashire, england
    79
    Red face
    I'm certainly enlightened. Thank you men.
    I look forward to trying "something different"
    T13.
    Dec 2002
    Benicia California USA
    7,417
    1487
    1711
    Go to the Schunk web site download and view the anamation on how it works...that chuck is not a scroll chuck at all. It is manual but the closing action works with cams and sliding (as linear) tooth plates. The jaws are quick change and can be reversed by just turning them around. Much higher gripping power than any scroll chuck, and higher accuracy due to the linear sliding elements not changing diameter as the jaw moves in as a scroll chuck does.
    That manual chuck costs about $6K ...one of the nicer work holding devices you will encounter, and the quick change jaw feature is very nice.
    If you don't want it PM me .....Just bought a similar one for my CNC Romi
    Cheers Ross
    Aug 2002
    West Unity, Ohio
    23,121
    3433
    6405
    Ox,
    A lathe?
    However - It's not something that I expect to need too often - and I have a 20" 3 jaw and hydro actuator to replace it ready to go on. However - since the ladder aint wrote for it - I will need to pony up a PLC in the control circuit to make it all work.
    Currently I'm looking for a diff style turret for it enyway...
    Think Snow Eh!
    Ox
  11. #11
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,700
    2435
    5274
    I bought a Methods Slant 50 once where previous owners removed the hydraulic chuck + draw tube, and installed a manual chuck simply because they needed a little more thru the chuck bore.
    Unfortuntely for me, the morons (Kennametal plant in SC) *lost* the original chuck, tube and closer. In the end I came out ok anyway, but how frustrating knowing that somewhere in the Kennametal system was sitting a brand new Kitagawa chuck, tube and closer and yet no one could find it...so it probably got scrapped !!
  12. #12
    Oct 2007
    UK
    1,742
    326
    420
    t13
    If its any help, have a look at the link below.
    They have a bucket full and would always talk a deal!
    http://www.dugard.com/used_machine_m...llaneous%20CNC
  13. #13
    Feb 2009
    Hendersonville, TN
    101
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Sounds like the ITW Woodworth Ball-Lock chucks I'm familiar with. They actually grip harder with more rpm. The jaws rotate on a ball a with a counterweight opposite the jaw.
    http://www.itwworkholding.com/products.php?p=1
    They are somewhat self centering and can be actuated by a drawbar. The grip range is smaller than a scroll chuck, but better than a collet. They work really well for high speed machining of castings like brake rotors.
