I don't have a tap for a missing part I am trying to make a replacement for that I intend to thread mill the internal threads for.
When manually programing thread milling, what is the proper or typical method for cutting? Do you go down the center of the hole and thread from the bottom up or do you thread mill down? And why?
I guess it has to do with chip evacuation and whether it becomes conventional or climb milling by the thread mill cutter. Also whether its right or left handed threads. But traditionally, looking at various literature and animation, thread milling right handed internal threads is typically done by plunging the cutter into the drilled hole with a rapid, and then at the bottom of the hole feeding the cutter to the cutting diameter, and then helical interpolate UP. Why is that?
The other method will be the more logical method to the uninitiated, which is to simply cut down into the hole every time no matter what. I suppose both method can work but is there a reason one is better than the other? Or is it always strictly a case of conventional vs climb milling? If so which one is best?
