Joec@westminster
- Mar 2, 2013
- Eastern CT, USA
I have an issue with my tool setter and wish to disassemble,clean and reassemble and cannot find any info on this. I do not know if it is even possible or not.
The issue I am having is I am getting intermittent "unexpected probe touch" errors or if the machine makes contact it does register it but then the z retract backs of very slowly rather than the rapid it normally does on the probe return after contact. If I gently touch the probe from the bottom, lifting it then the proper retract rapid speed is achieved.
As I understand the functioning of the probe it does not register the tool offset until the probe returns to its neutral position and then the machine rapids away. The machines behavior is telling me that the probe is not resetting to its neutral position. I am thinking it my be a worn or weak spring.
Any help is appreciated.
TYIA.
Joe
TYIA.
Joe
