PC in with Power supply???
FrankC
Apr 4, 2004
Hi
Is it a good idea to put PC componants in with power supply and Gecko's. I will be using one of the mini PC motherboards. I would like to have one box for CNC control.
Frank
If you are using switching power supplies they will generate a lot of high frequency noise. If you want it all in the same box, put a metal box around the power supply and run a connection to ground. This should shield most of the noise from your control.
