davestearman
- Jun 30, 2011
- michigan
I have purchased a Mazak QT-15 lathe and planning to move into the shop. Currently have 1 phase 220 power in the building. In the new section I have 125 amp single phase. Main shop has 220 200 amps. I am looking at a Perfect Phase electronic convertor rated at 20 HP and 64 amps output.
From what I can find Mazak wants 47 KVA supplied to the machine which is 123 amps at 220 three phase.
I understand if I change the parameters to slow down spindle ramp up and tool changer speed it will help.
My question is will this machine run on 64 amps or will I have to add more amperage and get a larger convertor?
If it won't run it what is the minimum I will have to have?
Dave
Dave
